Αποστολέας Θέμα: Οδηγός βερνικιών  (Αναγνώστηκε 219720 φορές)
Απ: Οδηγός βερνικιών
« Απάντηση #195 στις: Φεβρουαρίου 11, 2014, 02:33:19 μμ »
 13)I've used Tru-Oil on a couple of necks and on scrap pieces of wood, as
I was contemplating using it for a body.
[Note: I haven't used it on ash, only maple.]
The method I used was -- if I remember correctly -- very close to
what is suggested on the bottle. I apply a very thin coat with my finger,
rubbing the Tru-Oil in a bit but being sure to keep moving on before
it gets tacky. Since I apply a very thin coat I don't need to wipe off
excess. I lightly rub with 0000 steel wool between coats.
I have also wiped on with a cloth but my finger seems to work a
little better in getting a smooth finish.
I find that it's hard to keep the finish smooth as more layers of
Tru-Oil are applied. I can get quite a smooth finish with 3 coats,
but with 6 or more it's harder. On the back of the neck this is
no problem as I want I satin finish there, but on the headstock
it can be a problem.
The other problem with Tru-Oil is that it has poor "rubbing properties",
because it is a reactive finish. Unlike lacquer or shellac, the coats
of Tru-Oil don't fuse together -- which is one of the reasons you need
to use steel wool between coats. It you sand and use rubbing
compound after Tru-Oil there is a good chance you'll sand through
the top coat, and it will be noticeable.
For these reasons I've decided to use Tru-Oil only for necks.
But some people achieve beautiful glossy body finishes
with Tru-Oil. RomanS on this forum has done so, but he's
told me that he plans to use lacquer in future for a glossy
clear finish.
ps I don't think sanding to 600 or 800 is necessary. I think
going to 400 is more than enough.
Μετάφραση:
Έχω χρησιμοποιήσει  το Tru -Oil για κάνα δυο μπράτσα  και κομμάτια ξύλου , όπως
 σκεφτόμουν να το χρησιμοποιήσω για ένα σώμα .
[ Σημείωση : Δεν  το έχω χρησιμοποιήσει για ash(μελιά) μόνο για σφένδαμο. ]
Η μέθοδος που χρησιμοποίησα ήταν - αν θυμάμαι καλά - πολύ κοντά στο
τι προτείνεται στο μπουκάλι . Εφαρμόζω ένα πολύ λεπτό στρώμα με το δάχτυλό μου,
τρίβοντας το Tru -Oil  λίγο , αλλά βέβαιος πως συνεχίζω την κίνηση πριν
γίνει κολλώδες . Δεδομένου ότι εφαρμόζω ένα πολύ λεπτό στρώμα δεν χρειάζεται να σκουπίσω περίσσευμα. Τρίβω ελαφρά με το 0000 ατσαλόμαλλο μεταξύ των στρώσεων .
Έχω , επίσης, σκουπίσει με ένα πανί , αλλά το δάχτυλό μου φαίνεται να λειτουργεί
λίγο καλύτερα στο να πάρει ένα λείο φινίρισμα .
Θεωρώ ότι είναι δύσκολο να κρατήσω το φινίρισμα ομαλό  καθώς και περισσότερα στρώματα Tru -Oil εφαρμόζονται . Μπορώ να πάρω ένα αρκετά λείο φινίρισμα με 3 στρώσεις ,
αλλά με 6 ή περισσότερες είναι πιο δύσκολο . Στο πίσω μέρος του μάνικου
δεν υπάρχει πρόβλημα ,  καθώς θέλω ένα σατινέ φινίρισμα εκεί , αλλά στην κεφαλή
μπορεί να είναι ένα πρόβλημα.
Το άλλο πρόβλημα με  το Tru -Oil είναι ότι έχει φτωχές "ιδιότητες τριβής» ,
επειδή είναι ένα αντιδραστικό φινίρισμα. Σε αντίθεση με βερνίκι ή shellac , οι στρώσεις τους Tru -Oil δεν ενώνονται μαζί – ο οποίος είναι ένας από τους λόγους που χρειάζεστε να χρησιμοποιήσετε ατσαλόμαλλο μεταξύ των στρώσεων .  Εάν τρίβετε και χρησιμοποιείτε υλικό τριψίματος(rubbing compound) μετά το Tru -Oil υπάρχει μια καλή πιθανότητα να τρίψετε στην τελική στρώση , και αυτό  θα είναι αισθητό .
Για τους λόγους αυτούς, έχω αποφασίσει να χρησιμοποιώ Tru -Oil μόνο για μάνικα .
Αλλά μερικοί άνθρωποι κατορθώνουν όμορφο γυαλιστερό φινίρισμα του σώματος
με Tru -Oil . Ο Roman σε αυτό το φόρουμ  το έχει πράξει , αλλά
μου είπε ότι σχεδιάζει να χρησιμοποιήσει βερνίκι στο μέλλον για ένα γυαλιστερό
διαφανές φινίρισμα .
δεν νομίζω  πως το τρίψιμο με 600 ή 800 είναι απαραίτητο . Νομίζω ότι με
400 πρόκειται να είναι περισσότερο από αρκετό .
« Απάντηση #196 στις: Φεβρουαρίου 11, 2014, 02:36:19 μμ »
14)Without pictures and without being there, i am almost starting to suspect the grain filler, or perhaps the wood itself, and we are just guessing at the cause.
I've never had a problem with tru-oil. I dont use the sealer or grain filler on any wood. I use the oil itself as a grain filler/sealer.
I sand the body to at least 800gr... on open grained wood like ash I go to 1000 or 1500. I dust off the body lightly...some fine sanding dust is a good thing at this point. Then i switch back to a 400gr. wet/dry paper and "wet sand" the body using the oil. The oil mixes with the wood particles and turns into filler.
I sand with the grain untill the oil turns into wood colored clumpy goo and is almost dry.... then let dry for 10 or 15 minutes... then i wipe or rub off the excess going across the grain...checking often in a good light at an angle... you can see the pores getting filled in and where it needs more attention.
Once all the pores are filled, i allow the oil to cure ( usually 3-4 days in this dry climate), and then sand up to 800 + gr again before applying the actual finish. I check often to make sure i am not sanding out my filler, and I wet sand again as necessary using finer and finer gr. paper until I can't see any more pores. After the initial fill/curing, I usually only allow the following wet sandings to dry (usually overnight)
Then it’s as simple as wipe on, wipe off, allow to dry, rub, apply additional coats as wanted and buff when cured.
This all assumes that the wood itself is properly dried and cured.
Μετάφραση:
Χωρίς εικόνες και χωρίς να είμαι εκεί,  σχεδόν αρχίζω να υποψιάζομαι το υλικό πληρώσεως  , ή ίσως το ίδιο το ξύλο , και μόλις μαντεύουμε την αιτία .
Δεν είχα ποτέ πρόβλημα με το  tru -oil . Δεν χρησιμοποιώ σφραγιστικό (sealer)ή πληρωτικό πόρων(grain filler) σε οποιοδήποτε ξύλο . Χρησιμοποιώ ως υλικό πληρώσεως / σφραγιστικό το ίδιο το λάδι .
Τρίβω το σώμα με  τουλάχιστον 800άρι γυαλόχαρτο  ... σε ανοικτών πόρων ξύλα , όπως  η μελιά πάω στο 1000άρι  ή το 1500άρι . Ξεσκονίζω  το σώμα ελαφρά ... κάποια λεπτή σκόνη λείανσης είναι ένα καλό πράγμα σε αυτό το σημείο . Επιστρέφω σε 400άρι . υγρό / στεγνό γυαλόχαρτο και κάνω υγρό γυαλοχαρτάρισμα στο  σώμα με τη χρήση του λαδιού. Το έλαιο αναμιγνύεται με τα σωματίδια ξύλου και μετατρέπεται σε πληρωτικό .
Τρίβω σύμφωνα με τα νερά του ξύλου  εώς το λάδι να μετατραπεί  σε χρώμα ξύλου και να είναι σχεδόν στεγνό .... Στη συνέχεια αφήνω  να στεγνώσει για 10 ή 15 λεπτά ... τότε σκουπίζω ή τρίβω την περίσσεια ποσότητα  πηγαίνοντας εγκάρσια των νερών... ελέγχοντας συχνά σε ένα καλό φως σε μια γωνία ... μπορείτε να δείτε τους πόρους να γεμίζουν και όπου χρειάζεται περισσότερη προσοχή .
Μόλις γεμίσουν όλοι οι πόροι , θα επιτρέψω στο λάδι να σκληρύνει (συνήθως 3-4 ημέρες σε αυτό το ξηρό κλίμα ) , και στη συνέχεια τρίβω με 800άρι και άνω  ξανά   πριν από την εφαρμογή του πραγματικού φινιρίσματος .Ελέγχω συχνά για να βεβαιωθώ ότι δεν τρίβω ώστε να βγει έξω το υλικό  πλήρωσης μου , υγρό γυαλοχαρτάρισμα όσο χρειάζεται με  τη χρήση λεπτότερου και λεπτότερου  βαθμού  χαρτιού, έως ότου δεν μπορώ να δω πια πόρους . Μετά την αρχική πλήρωση / σκλήρυνση , συνήθως επιτρέπω μόνο τα ακόλουθα υγρά sandings να στεγνώσουν ( συνήθως τη νύχτα )
Στη συνέχεια είναι τόσο απλό -απλώστε επάνω, σκουπίστε , αφήστε το να στεγνώσει , τρίψτε , ισχύουν πρόσθετες στρώσεις όπως θέλετε και γυαλίστε , όταν σκληρύνει .
Αυτό προϋποθέτει ότι το ίδιο το ξύλο είναι σωστά αποξηραμένο.
« Απάντηση #197 στις: Φεβρουαρίου 11, 2014, 02:37:44 μμ »
15)hoover, you mention you are using paper towels to wipe off the excess? I would suspect that is your culprit. Paper towels will shread small particles. Try using old cotton t-shirts for everything. "old" cotton being it will have already gotten rid of its loose lint.
Μετάφραση:
Hoover , αναφέρατε ότι χρησιμοποιείτε χαρτοπετσέτες για να σκουπίστε την περίσσεια; Θα ήθελα να υποψιάζομαι ότι  αυτό είναι  ο ένοχος σας.  Οι χαρτοπετσέτες θα σχιστούν σε  μικρά κομματάκια. Δοκιμάστε να χρησιμοποιήσετε παλιά βαμβακερά t-shirts για πάντα.  Το  "παλιό" βαμβάκι θα έχει ήδη απαλλαγεί από το χνούδι του..
« Απάντηση #198 στις: Φεβρουαρίου 11, 2014, 02:39:30 μμ »
16)It is propbably little balls of Steel Wool that has gobbed up around a little bits of undried tru oil. Let it dry and just use different grades of sandpaper and see if your problem doesn't go away
Μετάφραση:
Είναι  πιθανόν μπαλάκια από ατσαλόμαλλο που έχουν γίνει μάζα  γύρω από  μικρά κομμάτια του μη ξεραμένου λαδιού.. Αφήστε το να στεγνώσει και να χρησιμοποιήσετε διαφορετικούς βαθμούς  γυαλόχαρτου και δείτε αν το πρόβλημά σας δεν συνεχίζεται.
« Απάντηση #199 στις: Φεβρουαρίου 11, 2014, 02:41:37 μμ »
17)I'll try to take some pictures tonight. It is tough to see these bumps because the light has to hit the body at the right angle to see it. The bumps show up in different spots too. I'll get an area smoothed out and on the next coat I'll get bumps somewhere else. I keep thinking it could be dust, but dust would come off easily with a light wipe of the steel wool right?
Also, once I get this thing done, what is the polishing technique to get a glossy finish?
The way that I rubbed the oil on, it was very smooth when it dried. I was able to polish it with nothing more than 3m polish. All you do is rub it with polish on an old tshirt until the finish is glossy. And I really recommend that when you're doing the oil, you try to apply it in a way so that there is nothing to wipe off- I don't think you're going to get it on smoothly enough if you are wiping off excess.
Μετάφραση:
Θα προσπαθήσω να πάρω μερικές φωτογραφίες απόψε. Είναι δύσκολο να δούμε αυτά τα φουσκώματα, επειδή το φως έχει να χτυπήσει το σώμα στη σωστή γωνία για να το δείτε. Τα φουσκώματα εμφανίζονται σε διαφορετικά σημεία πάρα πολύ. Θα πάρω μια περιοχή που είναι λειασμένη και στην επόμενη στρώση θα πάρω  φουσκώματα κάπου αλλού. Σκέφτομαι ότι θα μπορούσε να είναι σκόνη, αλλά και η σκόνη θα βγει εύκολα με ένα ελαφρύ σκούπισμα με  ατσαλόμαλλο σωστά;
Άπαξ και γίνεται αυτό, ποια είναι η τεχνική στίλβωσης για να πάρω ένα γυαλιστερό φινίρισμα;
Ο τρόπος που έτριψα  το λάδι, ήταν πολύ στρωτό(λείο), όταν στέγνωσε. Ήμουν ικανός να το γυαλίσω με τίποτα περισσότερο από 3M γυαλιστικό. Το μόνο που κάνετε είναι να τρίψετε  με γυαλιστικό  επάνω  σ’ένα παλιό t-shirt μέχρι το φινίρισμα να  είναι γυαλιστερό. Και ήθελα να συστήσω πραγματικά ότι όταν κάνετε το λάδι, μπορείτε να προσπαθήσετε να το εφαρμόσετε με έναν τρόπο έτσι ώστε να μην υπάρχει τίποτα να σκουπίζετε-Δεν νομίζω ότι πρόκειται  να το  πάρετε   αρκετά ομαλά, αν  σκουπίζετε την  περίσσεια.
« Απάντηση #200 στις: Φεβρουαρίου 11, 2014, 02:44:21 μμ »
18)You're not putting enough on.
I initially use a gloved finger to rub it into the wood fibers until the wood is sealed. It takes more coats to do this on ash than on maple for instance.
After the body is sealed, I use a lint free wipe saturated in Tru-Oil. I put enough product on that. Wait an hour or so before turning the body (depending on the humidity of your environment, I'm in AZ, things dry very quickly) so you don't get runs. As you've discovered, Tru-Oil is very soft and ablates quickly with sandpaper or steel wool. I do not steel wool between coats day to day as the finish will still seem almost tacky. IF I leave it alone for a week or more between coats OR if the coat was applied very thin and is therefor dry and hard, only then I will scuff it lightly.
After you get an apparent decent thickness, and it is kinda level and smooth, LEAVE IT ALONE for at least a month to get as hard and dry as it's goanna get.
Then you can very carefully wet sand and buff for an exceptional gloss.
2000-2500-3000 then your favorite liquid polishing compound.
I use Photex Scanner Wipes for the lint free oil applicator, also to buff the finish. Meguiars Carnauba wax to complete.
Μετάφραση:
Δεν βάζετε αρκετό   επάνω.
Εγώ αρχικά χρησιμοποιώ ένα  δάχτυλο(με γάντι) για να το τρίψω στις ίνες  του ξύλου μέχρι το ξύλο  να σφραγιστεί. Χρειάζονται περισσότερες στρώσεις για να το κάνουμε αυτό σε μελιά από  ότι στον σφένδαμο , για παράδειγμα .
Αφού το σώμα είναι σφραγισμένο ,χρησιμοποιήσω ένα πανί σκουπίζω το κορεσμένο Tru -Oil . Βάζω αρκετό προϊόν  επάνω σε εκείνο . Περιμένετε μια ώρα ή  περισσότερο πριν την περιστροφή  σώματος ( ανάλογα με την υγρασία του περιβάλλοντος σας , είμαι στην AZ , τα πράγματα στεγνώνουν πολύ γρήγορα ), έτσι ώστε να μην πάρετε τρεξίματα . Όπως έχετε ανακαλύψει ,  το Tru -Oil είναι πολύ μαλακό και αφαιρεί γρήγορα με γυαλόχαρτο ή ατσαλόμαλλο. Δεν τρίβω με ατσαλόμαλλο μεταξύ των στρώσεων μέρα με τη μέρα καθώς το φινίρισμα θα εξακολουθεί να φαίνεται σχεδόν κολλώδες . Αν το  αφήνω μόνο του για μια εβδομάδα ή περισσότερο μεταξύ των στρώσεων ή αν  η στρώση που  εφαρμόστηκε ήταν  πολύ λεπτή και επομένως είναι στεγνή και σκληρή , μόνο τότε θα το χαλώ(τρίβω) ελαφρά .
Αφού πάρετε ένα προφανές αξιοπρεπές πάχος , και είναι κάπως επίπεδο και λείο ,  αφήσετε το μόνο του για τουλάχιστον ένα μήνα για να γίνει τόσο σκληρά και ξηρό, όσο θα πάρει .
Στη συνέχεια, μπορείτε πολύ προσεκτικά  να τρίψετε με υγρό γυαλόχαρτο και να  στιλβώσετε(buff) για μια εξαιρετική γυαλάδα .
2000-2500-3000 , μετά το  αγαπημένο σας υγρό στιλβωτικό .
Χρησιμοποιώ Photex Scanner μαντηλάκια για την εφαρμογή του λαδιού , επίσης, για να στιλβώσω το φινίρισμα . Meguiars Carnauba κερί για να ολοκληρωθεί .
« Απάντηση #201 στις: Φεβρουαρίου 11, 2014, 02:46:19 μμ »
19)Are there any good instructions for wet sanding tru-oil?
Μετάφραση:
Υπάρχουν τίποτα  καλές οδηγίες για υγρή λείανση του  tru-oil;
« Απάντηση #202 στις: Φεβρουαρίου 11, 2014, 02:48:08 μμ »
20)Tru-Oil must be completely dry and cured. Real similar to color sanding.
2000 - just enough to level and remove defects, 2500-3000-compound, to shine.
Use a small rubber sanding block.
Extremely light pressure.
 Μετάφραση:
Το Tru-Oil θα πρέπει να είναι εντελώς στεγνό και σκληρυμένο.Έμπρακτα παρόμοιο με το χρώμα τριψίματος.
2000 - μόλις αρκετό για να επιπεδώσετε και να αφαιρέσετε ατέλειες 2500-3000- μίγμα, για να λάμψει.
Χρησιμοποιήστε ένα μικρό μπλοκ καουτσούκ για λείανση (εννοεί ένα λαστιχένιο τάκο με γυαλόχαρτο).
Εξαιρετικά ελαφριά πίεση.
« Απάντηση #203 στις: Φεβρουαρίου 11, 2014, 02:49:32 μμ »
21)I am really dumb about wet sanding, I've never done it. Am I actually using water to wet sand, or something else?
Μετάφραση:
Είμαι πραγματικά άλαλος για υγρή λείανση, ποτέ δεν έχω κάνει. Χρησιμοποιώ πραγματικά  νερό ή κάτι άλλο;
« Απάντηση #204 στις: Φεβρουαρίου 11, 2014, 02:51:08 μμ »
22)Yup.
You're not submersing the body, just wetting the sand paper. I use a small rubber sanding pad, not a large block. The water gets milky when sanding. That's the material you are removing. Rinse the sandpaper and wipe off the body often. Work in small areas where you really can control your finger pressure and observe what is going on. Stay away from edges. Wet sanding goes very quickly. With the 2000 or 2500, you are leveling the slight waviness in the hand applied Tru Oil. It does not take a lot. Wipe off the water often and make sure you can see what is going on. 3000 and polish brings the high gloss shine back.
Μετάφραση:
Yup.
Δεν καλύπτετε με νερό το σώμα, μόνο βρέχετε το γυαλόχαρτο. Χρησιμοποιώ ένα μικρό μαξιλάρι  λείανσης από καουτσούκ ,όχι ένα μεγάλο τάκο. Το νερό γίνεται γαλακτώδες κατά το τρίψιμο. Αυτό είναι το υλικό που θέλετε να αφαιρέσετε. Ξεπλύνετε το γυαλόχαρτο και σκουπίστε το σώμα συχνά.  Δουλέψτε σε μικρές περιοχές, όπου μπορείτε πραγματικά να ελέγχετε την πίεση των δακτύλων σας και παρατηρήστε τι συμβαίνει. Μείνετε μακριά από τα άκρα.  Το υγρό τρίψιμο πηγαίνει πολύ γρήγορα. Με το 2000 ή το 2500,  ισοπεδώνετε την ελαφρά κυμάτωση του εφαρμοσμένου με το χέρι Tru Oil. Δεν παίρνει πολύ. Σκουπίστε το νερό συχνά και βεβαιωθείτε ότι μπορείτε να δείτε τι συμβαίνει. 3000 και γυαλιστικό φέρνει  την υψηλής  στιλπνότητας λάμψη πίσω.
« Απάντηση #205 στις: Φεβρουαρίου 11, 2014, 02:52:19 μμ »
23)This is extremely helpful. What polish compound do you use?
Μετάφραση:
Αυτό είναι εξαιρετικά χρήσιμο. Τι γυαλιστικό μίγμα χρησιμοποιείτε;
« Απάντηση #206 στις: Φεβρουαρίου 11, 2014, 02:55:56 μμ »
24)It is very easy to sand through, but I was amazed that if you are very careful you can indeed wet sand and polish it, and I was very surprised at how glossy a finish it can be buffed up to.
It's more than oil. If you let it dry for a month to get good and hard, it will wet sand and polish.
If I were intentionally going for a super high gloss protective finish, Tru Oil would not be my first choice. There are easier, faster methods for sure.
I wanted the oil finish because I've heard nothing but good about the tonal qualities of an oil finished guitar. Also, 0000 steel wool on the neck provides the bare maple feel I love, but the wood is sealed and protected.
When I saw that I could get a fair bit of shine to it, that was an unexpected added benefit.
Μετάφραση:
Είναι πολύ εύκολο να  τρίψεις κατευθείαν, αλλά  εξεπλάγην   αν είστε πολύ προσεκτικοί μπορείτε πραγματικά να τρίψετε και  να το γυαλίσετε, και ήμουν πολύ έκπληκτος με το πόσο γυαλιστερά ένα  φινίρισμα μπορεί να λειαίνεται .
Είναι περισσότερο από το λάδι. Εάν  το αφήστε  να στεγνώσει για ένα μήνα για να γίνει καλό και σκληρό, θα υγρογυλοχαρταριστεί και θα γυαλίσει.
Αν σκόπιμα  πήγαινα για ένα σούπερ γυαλιστερό και προστατευτικό φινίρισμα ,  το Tru Oil δεν θα ήταν η πρώτη μου επιλογή. Υπάρχουν ευκολότερες, ταχύτερες μέθοδοι  στα σίγουρα.
Ήθελα το φινίρισμα λαδιού, επειδή  δεν έχω ακούσει τίποτα, αλλά καλό για τις τονικές ιδιότητες μιας φινιρισμένης με λάδι κιθάρα. Επίσης, 0000 ατσαλόμαλλο στο  μάνικο παρέχει την αίσθηση του γυμνού σφένδαμου που αγαπώ, αλλά το ξύλο είναι σφραγισμένο και  προστατευμένο.
Όταν είδα ότι θα μπορούσα να πάρω ένα καλό κομμάτι της λάμψη σε αυτό, ήταν ένα απροσδόκητο πρόσθετο όφελος.
« Απάντηση #207 στις: Φεβρουαρίου 11, 2014, 03:01:25 μμ »
25)Από thegearpage.net
I have a method that was taught ot me by Michael Tobias, its roughly a 5 day process
once the guitar is well sanded to at least 180 grit ( 220 is better)
Start with a "soak coat" first
Use a small rag to wipe on liberal amounts of oil and keep the surface wet for 10-15 minutes. Wipe off excess and let dry for as long as you want. but not less than 24 hours. this coat is very important as it seals the wood and the deeper the oil goes the better your protection against moisture later. pay attention to end grains as they soak up more oil.
2. Starting with 400 grit sandpaper. dip the sandpaper in a small amount of oil and sand in circular motions in a small area. the oil will begin to make a paste from the sanding dust, that you will want to push into the grain as much as possible. once the oil/dust paste starts to get stiff-ish, wipe off excess paste going across the wood grain. let dry another 24 hours. woods like ash ( or other wide grain woods) may require a sanding block to keep the wood surfaces flat. Clsoe grains like mahogany and Maples usually don't need a block.
3. Repeat step 2 useing 600 grit.
4. Repeat with 1200 grit
5. Take a 400 count cotton sheet and cut into a 12" square. roll into a very tight, smooth surfaced, ball.
use the ball as you did the sandpapers.. dip into the oil and "polish" the wood surface.
when the oil gets warm and stiff-ish,
wipe off VERY vigoursly WITH the grain, with a clean 400 count sheet ( balled up) damped with a VERY small amount of orange or lemon oil.
Buff and polish during and after this wipe off step and you should have a very nice glossy French polished finish. be careful of fingerprints.. as the oil drys, it will keep imprints in its surface.
I recommend you wear one cotton glove on one hand to hold the guitar with while you buff. watch for hard items on your worksurface. I fact I recommend that you use something soft to do this whole process on.
let dry another 24 and your done.
This type of finish is not for the nambie pambie.. It require tons of elbow grease. Do it wrong and it looks like crap. do it right and it looks like a million bucks. if your arm is not hurting halfway through step 2... your doing it wrong.
Good luck.
Μετάφραση:
Έχω μια μέθοδο που διδάχτηκε σε εμένα από τον Michael Tobias , περίπου μια διαδικασία πέντε ημερών
τη στιγμή που η κιθάρα είναι καλά λειασμένη με τουλάχιστον 180άρι ( 220 είναι καλύτερα )
Ξεκινήστε με μια   "απορροφητική στρώση"πρώτα.
Χρησιμοποιήστε ένα μικρό πανί για να απλώσετε μπόλικες ποσότητες  λαδιού και να κρατήστε την επιφάνεια υγρή για 10-15 λεπτά . Σκουπίστε το και αφήστε το να στεγνώσει για όσο χρονικό διάστημα θέλετε , αλλά όχι λιγότερο από 24 ώρες. Αυτή  η στρώση είναι πολύ σημαντική, δεδομένου ότι σφραγίζει το ξύλο και όσο  βαθύτερα πάει το λάδι τόσο  καλύτερη  η προστασία σας από την υγρασία αργότερα , να δώσετε προσοχή στα σόκορα , καθώς απορροφούν περισσότερο λάδι .
2 . Ξεκινώντας με 400άρι  γυαλόχαρτο , βυθίστε το γυαλόχαρτο σε μια μικρή ποσότητα λαδιού τρίψτε με κυκλικές κινήσεις σε μια μικρή περιοχή , το λάδι θα αρχίσει να κάνει μια πάστα από τη σκόνη λείανσης ,  θα θέλετε να πιέσετε στους πόρους του ξύλου όσο το δυνατόν περισσότερο , όταν η ελαιοζύμη / σκόνη αρχίζει να γίνεται δύσκαμπτη, σκουπίστε  την πάστα εγκάρσια με τα νερά του ξύλου , αφήστε να στεγνώσει για άλλες 24 ώρες. Ξύλα όπως  η μελιά ( ή άλλα ξύλα  με φαρδιά νερά ) μπορεί να απαιτούν ένα τάκο για να κρατήσει τις επιφάνειες του ξύλου επίπεδες.  Στενά νερά όπως το μαόνι και  ο σφένδαμος  συνήθως δεν χρειάζονται ένα τάκο.
3 . Επαναλάβετε το βήμα 2 χρησιμοποιώντας 600άρι γυαλόχαρτο .
4 . Επαναλάβετε με το 1200 άρι.
5 . Πάρτε ένα μετρημένο φύλλο βαμβακιού 400(εννοεί βαμβακερό ύφασμα)  και κόψτε σε 12 ίντσες  τετράγωνο  . Τυλίξτε το να γίνει πολύ σφιχτή , λείας επιφάνειας , μπάλα .
χρησιμοποιήσετε την μπάλα όπως κάνατε τα γυαλόχαρτα .. βυθίστε στο λάδι  και «στιλβώστε » την επιφάνεια του ξύλου .
όταν το λάδι θερμαίνεται και  γίνεται  stiff- ish ,
σκουπίστε ΠΟΛΥ σθεναρά με τα νερά του ξύλου , με  μια καθαρή νέα μπάλα βαμβακιού 400(ύφασμα)  ( μαζεμένη )  υγραίνετε με πολύ μικρή ποσότητα από orange η lemon-oil .
Στιλβώστε και  γυαλίστε κατά τη διάρκεια και μετά από αυτό  το   “wipe-off” βήμα θα πρέπει να έχετε ένα πολύ ωραίο γυαλιστερό φινίρισμα, να είστε προσεκτικοί των δακτυλικών αποτυπωμάτων ..  καθώς το λάδι  στεγνώνει , θα κρατήσει αποτυπώματα στην επιφάνεια του .
Σας συνιστώ να φοράτε ένα βαμβακερό γάντι στο ένα χέρι για να κρατάτε την κιθάρα , ενώ εσείς στιλβώνετε.  Κοιτάξτε για σκληρά στοιχεία  στην επιφάνεια εργασίας σας . Θα ήθελα να συστήσω το γεγονός ότι μπορείτε να χρησιμοποιήσετε κάτι μαλακό για να κάνετε όλη αυτή τη διαδικασία  .
αφήστε να στεγνώσει ένα άλλο 24ωρο .
Αυτό το είδος του φινίρισματος  δεν είναι για την pambie nambie .. Θα απαιτήσει  κοπιώδη σωματική εργασία. Κάν 'το λάθος και   μοιάζει χάλια . κάντο σωστά και   μοιάζει με ένα εκατομμύριο δολάρια . αν το χέρι σας δεν πονάει στα μισά του δρόμου μέσα από το βήμα 2 ...  το κάνετε λάθος .
Καλή τύχη .
« Απάντηση #208 στις: Φεβρουαρίου 11, 2014, 03:06:02 μμ »
26)For maximum gloss, I reduce the Truoil 50% with naphtha for the final coat. This reduces streaking from the rag too.
This works well, though I use mineral spirits instead, up to 50% mineral spirits is the recommended thinner / max ratio as per Birchwood Casey.
I use a lot of True Oil on my lap steels and one thing I've found is that TO is a very forgiving finish and everyone finds a way that works best for them.
My method has been a moving target and evolves a little each time. My way is certainly not the only way, its just a way that works for me.
For grain fill, I do the slurry wet sanding with True Oil much like Bruce described, though I use a big pink eraser as a block and sand with the grain.
Once I get the grain filled, I use a combination of wiping it on with a piece of lint free cotton, (large pre-cut gun cleaning patches), and then either spray the last couple final coats with a small gravity feed detail gun or do the thinned "glaze coat" as Ron described.
Given normal temps and conditions, you can recoat TO in a couple hours. The 'trick' is to not slop it on, full and even light coats works best.
For building body, I'll generally do 3 light coats a day wiped on with the direction of the grain. No need to over work it, I just lay it down with full long strokes and then give it a couple hours before the next light coat. Again, the key here is light coats, avoid the temptation to lay it on thick.
The next morning before any more coats, I take a small flat hard block and lightly wet sand with 1000 grit and a little spritz of mineral spirits for a lube.
For me, 1000 grit seems to be a good balance of grit at this stage as cuts fast enough to work without being overly aggressive on the new finish. Once I get a good level film built, I move up to 1500 for a day, then 2000 for a day. After the 2000, I do one light / full / quick "glaze coat" or spray the last coat and let cure a week.
 Μετάφραση:
Για μέγιστη λάμψη,  μειώνω το Truoil 50 % με νάφθα για την τελική επίστρωση . Αυτό μειώνει τις ραβδώσεις από το κουρέλι επίσης .
Αυτό λειτουργεί καλά , αν μπορώ να χρησιμοποιήσω mineral spirits αντ 'αυτού, μέχρι 50 % mineral spirit είναι η συνιστώμενη  / max αναλογία σύμφωνα με Birchwood Casey .
Χρησιμοποιώ πολύ από Tru  oil  σε lap steel κιθάρες και ένα πράγμα που έχω διαπιστώσει είναι ότι το tru oil  είναι  ένα  επιεικές φινίρισμα και όλοι βρίσκουν έναν τρόπο που λειτουργεί καλύτερα για αυτούς .
Η μέθοδός μου έχει υπάρξει ένας κινούμενος στόχος και εξελίσσεται  λίγο κάθε φορά . Ο δικός μου τρόπος  δεν είναι σίγουρα ο μόνος τρόπος , απλά ένας τρόπος  που λειτουργεί για μένα .
Για  το γέμισμα των πόρων ,  κάνω υγρό τρίψιμο με  τον πολτό με το True Oil  ακριβώς όπως ο  Bruce  περιέγραψε , χρησιμοποιώ  μια μεγάλη ροζ γόμα ως ένα τάκο και τρίβω με τα νερά του ξύλου..
Μόλις πληρωθούν οι πόροι ,  χρησιμοποιώ ένα συνδυασμό σκουπίζοντας το λάδι  επάνω με ένα κομμάτι πανί βαμβακερό , (large pre-cut gun cleaning patches), και στη συνέχεια είτε ψεκάζω τελευταίες  στρώσεις με ένα μικρής βαρύτητας τροφοδοσίας   πιστόλι  ψεκασμού λεπτομερειών  ή κάνω το αραιωμένο  "glaze coat", όπως περιέγραψε ο  Ρον .
Δεδομένων κανονικών συνθηκών και θερμοκρασιών , μπορείτε να  ξαναβάψετε σε μερικές ώρες . Το « κόλπο » είναι να μην το  ξεχειλίζετε επάνω , πλήρεις ομοίως  και λεπτές στρώσεις  λειτουργούν καλύτερα .
Για το  χτίσιμο του σώματος , γενικά  κάνω 3 λεπτά στρώματα την ημέρα σκουπίζοντας  με την κατεύθυνση των  νερών του ξύλου . Δεν χρειάζεται  υπερβολική εργασία, μόνο και μόνο θέτω το λάδι  με πλήρεις μεγάλες κινήσεις και στη συνέχεια δίνω μια-δυο ώρες πριν από την επόμενη λεπτή στρώση . Και πάλι , το κλειδί εδώ είναι οι λεπτές στρώσεις, αποφύγετε τον πειρασμό να το θέσετε επάνω παχύ .
Το επόμενο πρωί, πριν από οποιεσδήποτε περισσότερες στρώσεις , παίρνω ένα μικρό  επίπεδο σκληρό τάκο και κάνω ελαφρά υγρή λείανση με 1000άρι  και λίγο «spritz» των “mineral spirits”  για λιπαντικό .
Για μένα , το τρίψιμο με  1000άρι  φαίνεται να είναι μια καλή ισορροπία  σε αυτό το στάδιο , καθώς κόβει αρκετά γρήγορα ώστε να λειτουργήσει χωρίς να είναι υπερβολικά επιθετικό(τραχύ) στο νέο φινίρισμα . Μόλις πάρω ένα καλό  και επίπεδο  φίλμ κατασκευής, θα κινηθώ προς τα επάνω έως το 1500άρι  για μια ημέρα , στη συνέχεια, το 2000 για μια ημέρα . Μετά το 2000 ,  κάνω ένα ελαφρύ / πλήρες/ γρήγορο "glaze στρώμα” ή ψεκάζω την τελευταία στρώση και αφήνω να σκληρύνει  μια εβδομάδα .
« Απάντηση #209 στις: Φεβρουαρίου 11, 2014, 03:10:28 μμ »
Από  mandolinluthier.com
ΟΛΟΚΛΗΡΩΜΕΝΗ ΜΕΘΟΔΟΣ ΕΦΑΡΜΟΓΗΣ
What is it? Tru-Oil is a polymerized linseed oil with other natural oils added. This formulation will actually build-up as a finish unlike the raw or boiled linseed oils. Although this finish lacks the depth and gloss of lacquers or French polished shellac, the thin rubbed oil finish provides an appealing low luster sheen that enhances the natural beauty of the woods. The fact that it is thin and flexible, allows maximum vibration in the wood of musical instruments.
Ease of use? The real strength of this oil finish is that it is extraordinarily easy and safe to use. No special equipment or ventilation is required during finishing. Only clean cloths are needed for application with minimal sanding between coats. This finish is also much easier to repair and maintain than either lacquers or shellac.
Fill pores or not? Multiple thin coats can be applied directly to the raw wood for a very natural, open pore finish. The pores in hardwoods like rosewood can be filled first, so that the finish can be made to approach a factory lacquer finish.
How is it applied? The application is very simple. Just wipe the oil over the surface with a cloth. Wipe off any excess material leaving a very thin coating. This thin coat will harden enough in several hours to apply the next coat. Several coats are applied over several days to achieve the desired depth or thickness, with light sanding between coats.
Μετάφραση:
Τι είναι αυτό;  Το Tru -Oil είναι ένα πολυμερισμένο λινέλαιο με άλλα φυσικά έλαια που προστίθενται . Η φόρμουλα αυτή πραγματικά χτίζει σαν φινίρισμα σε αντίθεση με τα ωμά ή βραστά λινέλαια . Αν και αυτό το φινίρισμα δεν έχει το βάθος και την στιλπνότητα των βερνικιών ή του French polishing, το λεπτό  τριβόμενο λάδι  φινίρισμα παρέχει μια ελκυστική  χαμηλής γυαλάδας λάμψη που ενισχύει τη φυσική ομορφιά των ξύλων . Το γεγονός ότι είναι λεπτό και εύκαμπτο , επιτρέπει τη μέγιστη δόνηση στο ξύλο των μουσικών οργάνων .
Ευκολία στη χρήση ; Η πραγματική δύναμη αυτού του φινιρίσματος λαδιού είναι ότι αυτό είναι εξαιρετικά εύκολο και ασφαλές στη χρήση. Δεν απαιτείται ειδικός εξοπλισμός ή εξαερισμός κατά τη διάρκεια  του φινιρίσματος. Μόνο καθαρά πανιά χρειάζονται για την εφαρμογή με ελάχιστο τρίψιμο μεταξύ των στρώσεων . Αυτό το φινίρισμα είναι επίσης πολύ πιο εύκολο για την επισκευή και τη συντήρηση του από  τα βερνίκια ή την γομαλάκα .
Γεμίζουμε πόρους ή όχι; Πολλαπλές λεπτές στρώσεις μπορούν να εφαρμοστούν άμεσα στο ακατέργαστο ξύλο για ένα πολύ φυσικό , ανοιχτών πόρων φινίρισμα . Οι πόροι σε σκληρά ξύλα , όπως η  τριανταφυλλιά μπορούν να πληρωθούν πρώτα , έτσι ώστε το φινίρισμα  να προσεγγίζει έναν εργοστασιακό φινίρισμα  σαν την λάκα .
Πώς εφαρμόζεται; Η εφαρμογή είναι πολύ απλή . Απλά σκουπίστε το λάδι πάνω στην επιφάνεια με ένα πανί . Σκουπίστε τυχόν περίσσεια υλικού αφήνοντας ένα πολύ λεπτό στρώμα . Αυτή η λεπτή στρώση θα σκληρύνει αρκετά σε μερικές ώρες για να εφαρμόσετε την επόμενη στρώση . Οι διάφορες στρώσεις εφαρμόζονται επί αρκετές ημέρες για να επιτευχθεί το επιθυμητό βάθος ή πάχος , με ελαφρύ τρίψιμο μεταξύ των στρώσεων.
